2016 Camaro
Platform: F-Body & Zeta.
85 Camar-whoa!!
Old Jan 10, 2008 | 3:33 PM
GFunkk's Avatar
Default 85 Camar-whoa!!
got a question for you all, i have a 1985 camaro that i plan to max out. i have a 0010 block that is being bored and honed out as we speak. the block is getting a .040 over cut and i plan to use a 400 crank. the heads are stock heads, but they are getting thier share of work as well, port and polish with intake. new valve guides, studded rockers, wroller rockers, hydr lifters, 2.02 / 1.60 valve sizes, with a .016 mill. timing gear set, erson aluminium cover, i have chosen the popular victor, jr 4bbl 1500 idle intake and a 700 cfm holley. 7 quart oil pan with deep sump, and the tranny is 700r4. my question is, what kind of cam would you recommend, lift, duration so i can use the standard pushrods with no complications, but still maintain a kickass hp/torque on pump gas? and i am pretty sure that i want the MSD ignition system w/ points distributor, but what voltage do you recommend and what size alternator would you recommend? and i am keeping the block mount gas pump. And i want to use dual electric cooling fans for radiator. please help!
kota678
Oct 28, 2014 10:17 AM
