2016 Camaro
Platform: F-Body & Zeta.
87 z28 camaro
Old Sep 9, 2008 | 11:42 PM
mtn_maro's Avatar
Default 87 z28 camaro
always loved camaros and im getting my first one on thursday. it has some cosmetic issues that need to be taken care of tho. first off the front passenger fender needs to either have the dents be banged out or completely replaced. is it easy to remove the fender? i would think so. and then the drivers side mirror was victem of a hit and run. in order to remove it do i just pull off the interior door panel and unbolt it from inside? or is there some special way to remove it.
also it has the 305 4barrel with a dynomax exhaust. does the dynomax system add any worthy amount of power to it? or is it about the same as stock
Old Sep 18, 2008 | 10:32 PM
gmt900's Avatar
Default RE: 87 z28 camaro
third gen f body, my favorite i want to congradulate you on such a fine choice. you shouldn't have trouble removing the fender but i wouldn't say its easy either. it is time consuming.you want to take your time on any project and more on this one. you want to make sure you mark everything as a referrence point to put back together before you start dismantling. if you don't mark you'll have troublealigning your hood,and trouble with your door hitting the fender. also tape edges to preserve your paint. i've never had a dynomax but anyaftermarket exhaust is better than stock or so i think. if it hasn't already been done between me and you remove the catalytic converter.wait untill you register the car to passemissions first. it gives it a different exhaust note.also frees up some ponies.good luck on your new project, i remeber my dads z28's i think i slept in them for a week.
Old Sep 19, 2008 | 2:19 AM
mtn_maro's Avatar
im probably going to just leave the cat on. ill find other ways to free up ponies. ill put on new cats but im still going to keep them on
Old Dec 7, 2008 | 9:24 PM
Headers's Avatar
The dyno max will increase airflow by very little, and sound greatBut as far as hp boosting, get some nice headers on there, i suggest "Hooker Headers", or flowtech will be fine. Go dual exhaust in the back and get an x-pipe in the centre, that should... make 20+hp, witch is definatly noticable
silvia306
Mar 2, 2008 10:42 PM
e6bailey
Oct 17, 2007 2:38 PM
xlcrmoemoney
Jul 4, 2007 12:42 PM
dan7055
Camaro
Apr 8, 2007 4:58 AM
senor_coconut
Camaro
Oct 20, 2006 6:15 AM
