2016 Camaro
Platform: F-Body & Zeta.
89 camaro tuned port, no start
Old Jan 23, 2009 | 1:55 PM
tjlandrover's Avatar
Default 89 camaro tuned port, no start
WIll run on starting fluid, has spark fuel to the rails, security light goes out before crankinkg, thinking dist sensor coolant sensor, maf, vats clue less any help would be greatly appreciated...TOny
Old Jan 23, 2009 | 2:54 PM
shawnvw's Avatar
Banned
The first thing to check are your fuses. Specifically 2 fuses labelled Inj 1, and Inj 2. They provide power to both banks of injectors. Check them with the key in the ignition position, thats when they recieve power.
Your other possibilities would be either an ignition module, or the ecm itself.
The ecm controls the injectors directly, and it gets its signal from the ignition module. I would start with the ignition module as it is the cheapest and most readily available
Old Jan 23, 2009 | 9:54 PM
MDTAHOE's Avatar
Professional Mechanic
You need to check the fuel pressure may not be enough to run.
productepi
Jul 18, 2012 11:09 AM
tinbender59
26
Feb 21, 2011 10:33 AM
kayster
Nov 20, 2010 2:50 PM
verr1908
Sep 25, 2010 2:43 AM
obehave8802
Jan 27, 2007 9:40 PM
