ECM programming
ECM programming
I've recently installed an 01 vette LS1 into an 87 camaro.I used the vette instrament cluster,everything works except the fuel gauge.I was wondering if anyone knows if the vette ECM can be programmed to read only 1 tank(the vette has 2 tanks)?Also the information center keeps looking for input from things like ABS,traction cont.,tire pressures,etc...Can the cluster logic be reprogrammed?
Thanks
Paul
Thanks
Paul
fastblueheeler
August 12th, 2006 2:53 AM
Spudweiser
August 8th, 2006 12:33 AM
2002, 87, camaro, chevrolet, chevy, ecm, ecu, logic, programmed, programmer, programming, reprogram, reprogramming, silverado, tools
