2016 Camaro
Platform: F-Body & Zeta.
engine swap
Old Dec 8, 2009 | 3:48 PM
packgang23's Avatar
Default engine swap
i wanna swap engines out of my 1996 camaro z28 whats a good engine choice
Old Dec 8, 2009 | 4:07 PM
nauticstar87's Avatar
well, What do you want? you could just build the engine u already have, usually cheaper.
Old Dec 8, 2009 | 4:36 PM
myotherchevyisablazer's Avatar
it mostly depends on your budget!.....this one starts @ around $5500.....or there are some some starting @ around $2000 then you add some accesories....
<TABLE style="BORDER-COLLAPSE: collapse" id=AutoNumber2 border=0 cellSpacing=0 cellPadding=0 width="100%" height=46><TBODY><TR><TD height=14 width=813 colSpan=2></TD></TR><TR><TD width="100%" colSpan=2 align=middle><INPUT id=txtMainOrigImgSrc value=ProductImages/manufacturer/gm/images/17801268.gif type=hidden name=txtMainOrigImgSrc>
</TD></TR></TBODY></TABLE><TABLE style="BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD class=ProdDisplay1>GM Performance Parts LS6 Corvette Z06 Crate Engine </TD></TR></TBODY></TABLE>
Old Dec 11, 2009 | 11:42 PM
99FBODY's Avatar
If you want to build a motor I would go with the LS2, you can find the block pretty cheap and parts for the motor arent that expensive. Im wanting to swap out to the LS2 but I still have a lot of life left in my ls1, well see how it handles nitrous over the summer.
Old Dec 14, 2009 | 8:11 AM
packgang23's Avatar
Default ...
can you send me links on good prices of some
Old Feb 13, 2010 | 12:05 AM
72c10gunn's Avatar
your 96 has an lt1... the best thing to do is build a 383 out of it....get the lt4 heads and cam and it will be a screamer.....you can just tune your computer to math your engine build.....it would b much easier than swaping in a ls1,ls6,ls2ls3 or any ls based engine which doesnt even have the same type motor mounts and youd have to switch wiring harness and ecu
cueman
Feb 6, 2012 9:37 PM
BigSteve1206
May 16, 2006 8:50 PM
cleveman1
May 1, 2006 1:05 PM
Iowajeepin
Chevelle & El Camino
Apr 2, 2005 1:50 PM
