2016 Camaro
Platform: F-Body & Zeta.
no compression
Old Apr 26, 2010 | 8:30 PM
projectman69's Avatar
Unhappy no compression
i noticed my 355 camaro didn't seem like it was putting out much power. so i asked a buddy for a compression tester. i got the engine warmed up and made sure i did everything right. well the readings are as follows: 1-120/2-115/
3-0/4-110/5-0/6-100/7-120/8-120, the two with zero compression i checked 5 extra times to make sure. the thing is is that it has no bottom end power, but when you get going it really screams. has no signs of anything being out of whack just no comp. anyone know what is wrong??
Old Apr 26, 2010 | 8:38 PM
MDTAHOE's Avatar
Professional Mechanic
If it had zero compression it would run terrible all the time.
Old Apr 27, 2010 | 7:15 AM
I know that's what we were thinking too, but i rechecked them this morning after it ran and those two cylinders just barely feather the needle on the tester. the only thing we notice is that there is know bottom end power at all. you punch it to the floor and it just starts to roll off. there's no kick.
Old Apr 27, 2010 | 9:33 AM
Thumper_ehhhhh's Avatar
Well you could get lucky and just needs a new timing chain.
Old Apr 27, 2010 | 1:13 PM
we used a timing light and got it timed to 12 deg. for just the initial timing. when we hook up the comp,tester it makes a dif noise on those two cylinders. it's almost like air is whooshing somewhere. could it be just a head gasket?
Old Apr 27, 2010 | 3:32 PM
if your head gasket is gone you should see coolant in your oil. Pull the drain plug it should be coolant first as oil sits on top.
Old Apr 27, 2010 | 4:24 PM
Ya i know that's what everyone says, but nothing is happening to my coolant. it has not changed color and there is no antifreeze in the oil whatsoever. i was wondering maybe even a burned valve or something in that manner.
Old Apr 27, 2010 | 5:11 PM
hey i did a leak down test and found out what is wrong. well first of apparently both exhaust valves are shot and the head gasket has a leak. so could that be a power robber?
Old Apr 27, 2010 | 6:11 PM
Official GM Rep
I hope I'm not intruding but I see that you are getting this issue resolved by these community members here. If you need any extra help with other issues such as warranty work don't be afraid to reach out to me on here.
Jeff Morris, Chevrolet Customer Service
Old Apr 28, 2010 | 2:41 PM
77 chevy's Avatar
its not unheard of that a cam lobe wears flat... that could cause it 4 sure
