2016 Camaro
Platform: F-Body & Zeta.
no compression
Old Apr 28, 2010 | 7:37 PM
  #11
projectman69's Avatar
does anyone know approximately how much power is lost when a head gasket blows out between pistons? i figured that's where it is blown out because when i blow air into the cylinder air blows out the adjacent one next to it with force so there is definetly a leak in it.
Old Apr 28, 2010 | 7:38 PM
  #12
o and the cam only has 25000 miles on it. i'm not sure what the specs are on it though.
Old May 5, 2010 | 7:59 PM
  #13
72c10gunn's Avatar
If the cam wasnt broke in properly with break in oil or oil high in ZDDP then it will definitly wear some lobes off
Old May 28, 2010 | 8:22 PM
  #14
wylie coyote's Avatar
When you blow between 2 cyls, it will go and bridge in the narrow area. Likely not a loss of antifreeze. Easy way to check the cam is pull the valve covers and check the valve travel amount. You can likely do this visually, use a comparator if needed. If it's just those 2 holes it will be obvious watching it. My money is on the head gasket. Had times when I had both of these issues, so just my .02.
Wylie
69 pro street camaro/357
Old May 28, 2010 | 8:39 PM
  #15
One other thing- if the air is blown in one cyl, and you have it coming out of the other, it's the gasket. When a cam goes flat, the valves will lose lift, and remain closed longer.
shayandude
Jun 4, 2022 4:10 AM
cassijer
May 21, 2009 2:59 PM
steelhorse123
Dec 25, 2008 12:02 PM
1986c10
May 6, 2008 4:46 PM
