2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
rebuilt motor, and only 60 psi? no compression plz plz help
Old May 30, 2009 | 4:00 AM
shayandude's Avatar
Default rebuilt motor, and only 60 psi? no compression plz plz help
hey guys,
im back once again,
i got the 03 impala with the 3.4 liter.
the cylinders have any where from 40- 90 psi of compression.
the mechanic said that it was the rings that havent sat yet.
what can i do about that?
will that compression rebuild in a bottle work?
plz help im desperate.
Old May 30, 2009 | 8:44 PM
shawnvw's Avatar
Banned
If it is the rings, a few squirts of fresh oil in the combustion chamber should fix it.
Pull all the plugs, squirt some oil into each spark plug hole, reinstall plugs and try to start it. The oil will seal the compression loss at the rings and if thats all it was, it should start right up. It'll smoke like crazy for a while though.
I had this on a Neon once. Did a head gasket in the driveway for a buddy, and because it sat in the driveway for a week, the oil drained from the cylinder walls causing no compression
Old May 30, 2009 | 11:14 PM
shayandude's Avatar
hey,
thanks for your reply,
he tired that, and the compression came up some and it smoked like crazy for few minutes, but soon dies back down, he hooked up this snap on tool that hooks up to a air hose and then goes to where the plugs go, and on most of them there was a 40% leak. we listened to the air intake, no sound, listened to the muffler nothing, its coming from the cylinders, and he said its the rings that havent seated. i saw this compression rebuild at advance auto. does that really work?
i cant afford to start over.
Old May 31, 2009 | 7:28 AM
shawnvw's Avatar
Banned
If adding oil to the cumbustion chambers didn't work, I doubt that compression rebuild will....but its worth a try.
Who rebuilt the motor for you?
Old May 31, 2009 | 7:32 AM
valve timing issue?
Old Jun 1, 2009 | 6:46 PM
shayandude's Avatar
well its a friend of the family, but he is a mechanic. ase ceritfied and all that good stuff.
well thats what i asked him. abotu the timing, but the chain went on right, and those tabs lined up. i just cant afford to re rebuild it. any suggs? of what i should do?
Old Jun 4, 2022 | 4:10 AM
HHR guru's Avatar
Default Get a better mechanic
Originally Posted by shayandude
hey guys,
im back once again,
Find a better mechanic.. more than likely it's an issue with the head, not the pistons
HHR guru's Avatar
hey guys,
im back once again,
Big tiny
Jul 28, 2011 11:51 AM
sdrammm696969
Oct 10, 2010 1:37 PM
shayandude
Mar 11, 2009 5:39 PM
adk683
Aug 12, 2007 6:54 PM
