2016 Camaro
Platform: F-Body & Zeta.
pinging problem on my 76 camero
Old Feb 17, 2010 | 3:28 PM
hunter51190's Avatar
Default pinging problem on my 76 camero
hi i have a 1976 chevy camero with a 350. The motor has a elbrock 600cfm carb, elbrock performer intake, branded new ported 202 heads, thumpr camshaft, stock bottom end as fare as i no. Just put my top end together and i am having a bad pinging problem under load between 1000 to 3000 rpm, i tried 91 octane gas, i richened up my carb and i advancted the timing. Nothing seems to work, can anyone help? do i need more octane? i am running a 476 lift cam and know i am ok on clearance, also it only does it once the engine is a full heat which i am running a 185.can anyone help?
Old Feb 17, 2010 | 5:01 PM
72c10gunn's Avatar
try a colder spark plug, i would retard the timing rather than advance it....try the timing first and if that doesnt work try plugs....have u done a compresin test to see what your cranking compresion is?
Old Feb 17, 2010 | 7:27 PM
I haven't, I wanna try to leave the timing advanced as much as possible because I get much more performance out of it. It has much better reaction and get up and go advanced. Could the valves need adjusted again after I put the came in and ran it?
Old Feb 17, 2010 | 10:11 PM
maxxman04's Avatar
problem is you'll get the pinging if timing is advanced too far. yeah, you'll get a bit more power, but you do run the risk of grenading a piston, maybe. and of course, the pinging.
Old Feb 18, 2010 | 8:11 AM
thank you, I will try this. I had the feeling that was why, but before when u had a smaller cam I had it very advanced so I didn't think that was it, but with a 476 lift it must just me enough to hit. Thanks everyone
Old Feb 19, 2010 | 6:14 PM
72c10gunn's Avatar
wait pinging is caused from predetanation....either too much timing and/or too much compression for what fuel ur using....if you have valve clearance problems then thats a diffrent problem. the bigger cam should have made it less likely to ping than the smaller cam....
sharpear
Camaro
Jan 5, 2011 9:28 AM
game1939
Feb 19, 2010 5:28 PM
Wind in my hair
Camaro
Jul 30, 2008 12:41 PM
camarogirl030182
Jan 28, 2008 10:50 AM
GaDirtRacerGurl
Camaro
Jan 17, 2006 7:16 PM
