2016 Camaro
Platform: F-Body & Zeta.
Temp Gauge issue
Old Sep 8, 2020 | 7:11 PM
hawks000's Avatar
Angry Temp Gauge issue
Trying to get some help on a 1997 3.8 Camaro that I have been working on for a while. The issue is that the PCM Temp and the Gauge in the cluster does NOT match. THE Gauge is reading about 50-60 degrees higher then the PCM temp. I have verified the PCM with my OBDII scanner. The PCM temp is running about 195-200 (195 degree thermostat) the Gauge is reading 250 + (most time pegs it out) and causes the "Check gauges" light to come on.
This car only has ONE sensor that feeds BOTH the ECM & Gauge
  1. Wire Goes to the PCM(Yellow)
  2. Wire is ground (Black)
  3. Goes to the Gauge Cluster (green)
The things I have tired are
  • Changed Temp sensor with New
  • changed Cluster out with a Known good cluster
  • Cut and changed the wiring Connector @ the sensor
  • ran a new (Green) wire from the sensor to the last connector I could get to before the wires go under the dash . I can NOT get to the back of the cluster to run a completely new wire
So what am I missing ? Can someone give me some advice on what to try next ?
Thanks in advance
john2000
Apr 26, 2020 12:41 PM
JoseDinero
Mar 10, 2015 9:21 AM
Fishinfooleric10@aol.com
Feb 20, 2013 9:04 AM
gdcpony
Nov 30, 2012 1:01 AM
Ryan
Aug 10, 2009 12:39 AM
