Platform: B-Body
1985 chev caprice won't run.
Old Sep 5, 2006 | 8:09 PM
sbredeson's Avatar
Default 1985 chev caprice won't run.
I have a chey 1985 caprice classic which quit the other day.
I replaced the fuel pump and verified I have fuel pumping to the carb by loosing the bolt that holds the filter in. I still can’t get it to run.
I pulled the distributor and the coil looks fine, the cap and rotor look good.
When I pull a plug and turn it over I do not see any spark. I did verify I have 12 volts going to the coil. Just wonder if the next step is replacing the control module or if there is anything else I should check?
Old Oct 2, 2006 | 12:23 AM
2005 Equinox's Avatar
Default RE: 1985 chev caprice won't run.
Try a different ignition module. These can and do go. If the coil checks out then this is the next step.
Old Oct 2, 2006 | 5:34 PM
uncle bill's Avatar
Go ahead and replace that cap and rotor. The HEI is notorious for problems in that area. Replace the ign. module also.
jacolbyhud
Mar 5, 2014 11:05 AM
J31Rob
Sep 27, 2012 2:30 PM
J31Rob
Jul 18, 2012 10:04 PM
1985Classic
Jul 18, 2012 5:32 PM
bentwrench
Aug 25, 2011 5:52 PM
