Platform: B-Body
1990 radio speakers grounds???
Old Mar 18, 2019 | 6:13 PM
Brandon64123's Avatar
Default 1990 radio speakers grounds???
Radio works but speakers aren't putting out accurate sound. I got one speaker to work but when I put the car in park it stopped working. Which grounds do I need to trace. i have taken out the dash and messed with the speaker wires but not sure where the grounds are.
Old Mar 19, 2019 | 8:00 PM
Maynard G. Krebs's Avatar
Default radio speakers - grounds?
Brandon,
I'm not an expert...... but I do know that some cars have a radio system which does not use the chassis ground as the ground for the radio output(s).
I would research the owner's manual, first. I remember that in some 1980s Buicks that I had, there was a warning and explanation as regards electronic equipment, both what the car came with... and possible aftermarket additional equipment.
I would try to get a wiring diagram for your car. Then, go into the trunk and try to determine the color(s) of the wires that are attached to the rear speakers. Write these down.... on one side of the paper for the Left side of the car... and on the other side of the paper, write the wire colors at the right side speaker. You might be able to follow the wiring diagram with this information.
But, maybe more importantly, you need to find out whether your car radio uses a "chassis ground"... or a "floating ground".
That's as much as I can provide --- good luck.
Old Mar 20, 2019 | 1:56 PM
They use 2 wires from the radio to each speaker. So they don't use the chassis ground for the speakers. This is a typical wire layout for radios
.EIA Electronic Industries Association Color Coded
Yellow12 Volt memory
Red12 volt ignition
Orange dash light illumination
Black radio chassis ground
Blue power antenna
White left front +
White/Blk left front -
Green left rear +
Green/Blk left rear -
Gray right front +
Gray/Blk right front -
Violet right rear +
Violet/Blk right rear -
Old Mar 21, 2019 | 9:59 AM
Irish_alley's Avatar
I'm here for the party
i every 88-98 ive been in has had issues with the stock speakers. not saying theyre bad but i think its more of a poor connection to the speaker
Old Mar 21, 2019 | 11:07 AM
They used to use cheap speakers with paper cones which didn't last very long. the cones cracked causing them to make rattling sounds. My 2013 has better speakers in it and so far they are still good.
Old Mar 23, 2019 | 4:38 PM
Default re: OEM radio speakers
I, too, have had scratchy noise problems with OEM speakers in the 1980s GM vehicles that I have owned.... but especially noticing that every time, it's the right side speaker... and usually the rear one.
So, I've wondered if maybe the capacitor for the right side of the vehicle, inside the generic GM AM-FM radio, usually "went bad" due to heat from some nearby electronic part inside the radio... like a resistor, or something else that generates heat.
I do readily understand that, all things being equal, that it's more likely or more reasonable to suspect the speakers... in a 30-year-old car.. than "internal electronics".
But, I can't believe that it's coincidence that in both of my '89 Caprices, that it's always been the right side speaker... that goes bad.
Old Mar 23, 2019 | 4:51 PM
kevinkpk's Avatar
Finger nail polish on the paper, if it sputters, probably have a cut.
