Platform: B-Body
93 caprice wont stay charged HELP
Old Oct 5, 2010 | 5:12 PM
Capriceon2s's Avatar
Default 93 caprice wont stay charged HELP
i just got the car and wont hold a charge i have put new altanater and battery but still wont hold a charge i hve no clue what i should do about it any help would be great thanks
Old Oct 16, 2010 | 10:40 PM
2wd-K5's Avatar
u have a short, do u have any particular fuse that blows on a regular basis? (if u dont want to trace the wire that is shorting, just put in a night switch)
Old Oct 30, 2010 | 9:23 PM
1967SS396's Avatar
There is something in your car that is on and draining your battery..Trunk , hood light etc.
Remove one of your battery terminals, NEG , and see if you get a small arcing when you make a light contact with them..Or use a meter across the terminals...If you do, then you are drawing power from the battery. That is if everything is turned off.. Remove one fuse at a time and check for arcing.Once it stops you know that that system is the problem..
dlmccray8
Sep 8, 2012 8:45 AM
Tommy
Feb 14, 2012 7:14 PM
Kharn
Jun 12, 2007 6:38 AM
uncl3_fock3r
Feb 3, 2007 1:22 AM
