Platform: B-Body
Caprice Upgrade
Old Aug 10, 2006 | 11:19 PM
mopar's Avatar
Default Caprice Upgrade
I have a 1992 Caprice with an old 305. I would like to put a blown 327 in it, but i don't if im going to need a cross member for the frame so the chassis doesn't twist or flex. The main problem is it has a 2" drop, and i putting dual exhaust on it and that would leave much room under there for cross braces. Is there another solution?
Old Aug 30, 2006 | 1:28 PM
dragonrpc's Avatar
Default RE: Caprice Upgrade
Mopar,
I did respond to your e-mail, sorry for the late response.
Old Aug 30, 2006 | 2:52 PM
kcb37's Avatar
I would cost more but if you split your pipes agian and had them flattened over the crossmember. If you have enough room. I say split it again because you will still keep most if not all of your flow over a big choke point.
Old Mar 11, 2007 | 3:47 AM
btotheh33's Avatar
box the frame rails.
Justin96ss
Jan 30, 2015 4:45 PM
Justin96ss
Jan 30, 2015 4:42 PM
reminc70
Dec 24, 2007 12:50 PM
onebigbass
Jun 4, 2006 8:05 PM
