Platform: B-Body
engine lugs down with trans in gear when cold?
Old Nov 30, 2011 | 1:00 AM
chevyguy140's Avatar
Default engine lugs down with trans in gear when cold?
im just looking for some help with a problem that just showed up. here is the problem. when i shift the trans into reverse or any gear with the engine cold the engine bogs down almost to the point of stalling out. but it only does it when the engine is cold once warmed up it goes away. and it also seems to be quite sluggish while driving when the engine is cold but again it goes away once the engine gets to operating temp. any tips from anyone to enlighten me on this problem and to possibly remedy it would be appreciated thanks
Old Nov 30, 2011 | 2:19 AM
btw if any one is curious the car is an 89 capreice classic with a throttle body injected 350 sbc and a th700r4 transmission
Old Dec 5, 2011 | 11:11 PM
ComradeCostello's Avatar
How many miles are on it, and the even better question, when have you changed your spark plugs and wires last, or if ever? If you engine is lugging and idling rough on a cold block, plugs are the first thing to give a check out.
Old Dec 6, 2011 | 1:16 PM
91Caprice's Avatar
Could also be a distributor issue.
Old Dec 14, 2011 | 2:01 AM
well i just changed the plugs wires cap and rotor and set the timing to spec and now it actually dies sometimes whether it is cold or warm.
Old Dec 14, 2011 | 8:27 AM
91Caprice's Avatar
Old Dec 14, 2011 | 9:22 AM
Like 91' was saying, distributor man. It'll cause the same problems.
djoker04
Feb 21, 2011 6:35 PM
djoker04
Astro
Jan 24, 2011 3:42 PM
nauticstar87
Oct 31, 2009 9:28 PM
TonyV
Aug 13, 2009 9:38 PM
NBx33
Jun 19, 2008 12:23 PM
