Platform: B-Body
Engine swap
Old May 22, 2016 | 8:46 PM
Antoine Childs's Avatar
Default Engine swap
Just swapped out a stock 305 for a 350 in my 93 caprice. Can feel the difference in power, but now I'm noticing a hiccup when I accelerate. Wondering if it could be a fuel injection problem...any advice?
Old May 26, 2016 | 5:48 AM
MaximGo's Avatar
Hey! Sorry for the bad English, I use a translator. Perhaps failures when you press on the gas pedal of a badly exhibited ignition (coil and candles) on a new engine 350m. Perhaps distributor in bad condition.
I would draw your attention to the fuel pump, if it is stock, then you need to put a more powerful fuel pump, just try to change the engine control module, it may be necessary to change to one that set 350 engine
Old May 26, 2016 | 5:49 PM
So, basically, it would be best to change out the ecm, fuel pump, and distributor?
Old May 28, 2016 | 4:00 PM
MaximGo's Avatar
I'd start by checking the distributor ignition and exhibiting the ignition stroboscope
Old May 28, 2016 | 4:07 PM
bandit_601948's Avatar
it might be an injector problem ! did you try running some injector cleaner in the tank ? it also might be the fuel regulator too , or no vacuum going to it ! if it has a carburetor then it could be the accelerator pump inside the carburetor ! did you check the fuel filter, it might be partly clogged !
Old Jan 22, 2017 | 3:27 PM
WyrTwister's Avatar
My bet is you need the " computer " from the donor car .
God bless
Wyr
