Platform: B-Body
Knocking When A/C or Heat Is Turned On
Old Sep 6, 2016 | 6:00 PM
Bruh_Built's Avatar
Default Knocking When A/C or Heat Is Turned On
Thinking about buying a 91 Caprice from a friend. It's a solid vehicle, but it makes an awful knocking type sound when you turn the A/C or heat on. It purrs like a kitten if they are off. Any ideas? Thanks in advance.
Old Sep 7, 2016 | 1:59 PM
kevinkpk's Avatar
Post a video of it.
Old Jan 22, 2017 | 3:06 PM
WyrTwister's Avatar
When you turn the heat on ? Look & see if the compressor is rotating / functing when the heat is on ( not just the compressor pulley , but the clutch is rotating also ) .
Check the belt powering the compressor pulley .
You sure the noise is not from the inside climate control fan ?
God bless
Wyr
