Rochester Carb
Rochester Carb
Hi guys, need to understand something.
As you can see carb is leaking fuel on the fuel fitting.
Someone has tried welding the fitting as u can see.
Question is, if I buy a new fuel fitting, there is a nut on the fuel line that screws on the fuel fitting. When I unscrew it will I be able to reuse the nut attached to the fuel line?
Yes. It is a flared fitting that will remain attached with the fuel line.I recommend a fitting wrench, as you can see the flats on the nut are some what rounded.
BTW anywhere to buy fuel line pump to carb? Or can u can convert to rubber fuel hose?
I say this because at a 90 degree bend on the fuel line there is a small kink..
overdrive87
June 29th, 2014 11:00 PM
JLanzino
November 23rd, 2011 2:25 PM
