Platform: B-Body
Rochester Carb
Old Nov 30, 2019 | 8:15 AM
VdoA's Avatar
Default Rochester Carb
Hi guys, need to understand something.
As you can see carb is leaking fuel on the fuel fitting.
Someone has tried welding the fitting as u can see.
Question is, if I buy a new fuel fitting, there is a nut on the fuel line that screws on the fuel fitting. When I unscrew it will I be able to reuse the nut attached to the fuel line?
Old Nov 30, 2019 | 8:19 AM
kevinkpk's Avatar
Yes. It is a flared fitting that will remain attached with the fuel line.I recommend a fitting wrench, as you can see the flats on the nut are some what rounded.
Old Nov 30, 2019 | 9:54 AM
VdoA's Avatar
Do you know what size the fitting wrench needs to be?
Old Nov 30, 2019 | 10:53 AM
kevinkpk's Avatar
5/8 ". There is supposed to be a filter in there behind the fuel line, but it looks like it's been jacked with.
Old Nov 30, 2019 | 3:54 PM
VdoA's Avatar
Yeah from the research I did also found that out. Thanks!
BTW anywhere to buy fuel line pump to carb? Or can u can convert to rubber fuel hose?
I say this because at a 90 degree bend on the fuel line there is a small kink..
Old Nov 30, 2019 | 6:19 PM
kevinkpk's Avatar
I'd use the steel line to carb, and the opposite end. Hose clamp with gasoline line in between.
sachewie
Apr 3, 2018 12:32 AM
Louie Chavez
Jul 11, 2017 4:18 PM
overdrive87
Jun 29, 2014 11:00 PM
JLanzino
Nov 23, 2011 2:25 PM
reillymax
Chevelle & El Camino
Apr 19, 2008 10:17 PM
