Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
Captiva 7 diesel can’t solve code P0340
Old Sep 8, 2023 | 12:31 AM
Charlie Bailey's Avatar
Default Captiva 7 diesel can’t solve code P0340
Captiva 7 2.2 diesel . LNQ motor camshaft sensor fault P0340 .
symptom . Car will not start with cam sensor connected
Will start when disconnected
Mil light on
fault codes P0340 P0341
Have egr code P0487 (not sure if related )
Issue , does not have Crank Position Sensor reading when cranking with cam sensor connected . (No crank shaft DTC ) no start
Disconnect cam sensor get crank sensor
Reading and start .
both sensors replaced. Timing and Reluctor checked correct .
5v power and signal to cam sensor checked earth checked
Bypassed harness. wired sensor to just above ecu .
Ecu replaced still same .
Seems like corruption somewhere
have run with drive belt off as poss spikes from alternator.
any body seen anything similar have not done much work on these cars thanks Charlie .
will be something small can’t put my finger on it
thanks Charlie
Old Apr 4, 2024 | 3:44 AM
rednut77's Avatar
Default It wasnt maroon was it i
did you ever solve this i thie the same problem
Yogi
Apr 2, 2026 5:33 PM
JimOmaha
Nov 12, 2022 7:26 PM
Wiseone
2007 - 2013 (GMT900)
May 27, 2021 3:35 PM
gnorton52
May 23, 2011 11:59 AM
ottof
Jan 8, 2008 10:39 PM
