Platform: J-body
03 2.2 cranks no start
Old January 28th, 2021, 5:32 PM
  #11
Jiyu's Avatar
Might be time to run a compression check.....you know, see if maybe something expensive is causing your trouble....
You wrote that you replaced the crank sensor... Was it a new OEM sensor or a junkyard or cheap aftermarket part? Did you check the wiring to the crank sensor for corrosion, etc.?
Old January 28th, 2021, 5:54 PM
  #12
Billy Bee's Avatar
New from parts store. Connector looked good. Didn't check wiring, as I do not know the specs between wires. If anyone has them that would be helpful. Had continuity between pins on old and new sensor.
Old January 30th, 2021, 7:45 AM
  #13
Billy Bee's Avatar
I also pulled the valve cover to try and see where the cams were at. I believe the cam sprockets are held in place on the cams only by the bolt friction? No keys or anything? Why would this be a good idea? But any who, based on pictures I see that when #1 cyl (closest to passenger side?) Is at tdc, the exhaust triangle on cam sprocket nearest firewall will be pointing about 10 o'clock while the intake diamond on the cam sprocket will be pointing approx 2 o'clock.
I couldn't get this configuration and unfortunately only one colored link was seen. Guessing the other markets wore off. If anyone can confirm the above orientation is correct that'd be great. Will be performing a compression and leak down test soon.
Old January 30th, 2021, 2:36 PM
  #14
Jiyu's Avatar
Easy way to check cam timing: With the piston at TDC on compression, both valves should be closed.
Old January 30th, 2021, 2:41 PM
  #15
Jiyu's Avatar
Stick your finger into the exhaust pipe and wipe the inside wall with it - if it comes out oily, 'There's your problem lady.'
Firefox64
March 27th, 2016 5:11 PM
undertow911
May 6th, 2014 9:18 AM
Bob1945
December 23rd, 2012 1:43 PM
redneckjames
October 19th, 2011 8:02 AM
brownkobe8
March 31st, 2007 1:20 AM
Quick Reply: 03 2.2 cranks no start
