Platform: J-body
1997 Cavalier 2.2L problems
Old May 12, 2014 | 10:14 PM
97cavtrain's Avatar
Default 1997 Cavalier 2.2L problems
I am experiencing a bad misfire in my 1997 Cavalier 2.2L until the engine is up to operating temperature. A few weeks ago I discovered a very bad cold idle but new plugs fixed it and the car ran fine until sunday morning. It starts fine and idles fine for a few seconds then as the idle comes down it starts misfiring and doesnt stop until a few miles of driving. I put in a new IAC and ECT over the winter. What do you guys think of this? What would cause a bad cold idle and misfire that goes away completely when the engine is warmed up? Thanks for any advice/info.
Old May 13, 2014 | 4:35 AM
Segfault's Avatar
A shot in the dark, check compression?
Old May 16, 2014 | 6:59 PM
93Cavi22's Avatar
Dirty fuel injectors? Since the plugs helped, maybe the fuel/air is off. Try running some cleaner through the fuel system and check how dirty the throttle body is. I like Lucas and use it at least once a year. Also, try resetting your ECU by disconnecting the battery for half an hour, it may be setting some of the cold parameters wrong.
Old May 18, 2014 | 12:28 PM
97cavtrain's Avatar
Ok an update: I replaced the plug wires and the bad miss went away. I didnt replace the plug wires sooner because they arent that old. Anyway the car starts and runs fine but idles low and will sometimes shut off when I come to stops unless I "2 foot it". This makes me think a problem with IAC but I replaced that a few weeks ago. One thing I noticed was that the new IAC was the bulkier black plastic valve type instead of the stock pointy metal type it originally had. Could this be an issue?
Old May 21, 2014 | 5:59 PM
93Cavi22's Avatar
If the IAC fit, it is probably the right one. You can rotate it slightly after loosening the bolts, maybe that would raise the idle. You can check the intake manifold for black build-up in the idle air-way. A clean idle air passageway might fix it. Good Luck!
perry2326
Oct 19, 2013 10:25 PM
dizturbed
Jan 20, 2010 1:38 PM
dpotgieter
Sep 10, 2008 4:19 PM
thecav1997
Mar 1, 2007 11:48 AM
