1997 cavalier
I would agree that is likely a electrical issue, when you apply the brakes the tail lights are creating a current draw that is pulling down the system OR you have an electrical short in the fuse / relay box....
Might want to start with checking the battery cable connections and the connections at the alternator, check the ground cable for corrosion..
