Platform: J-body
1997 cavalier wont start
Old Jan 2, 2010 | 6:51 PM
aream2000's Avatar
Default 1997 cavalier wont start
first off cars are not my thing computers are so im sorry if this sounds stupid
i went out the other morning to start my car it sounded like it was going to start but it never did, i have a full tank of gas and the battery is fully charged, i just had the oil changed about a month ago, any help would be appreciated
Old Jan 7, 2010 | 1:33 AM
todds96cav's Avatar
Does it crank but not fire? If it'll crank but just not start you need to check a few basic things.
1.when first turning the key to the on position,listen to see if the fuel pump is priming.You should hear a quick buzz coming from the rear of the car.The fuel pump is mounted in the tank.
If you don't hear anything try banging on the bottom of the gas tank with a rubber mallet and try again.Also check your fuses and relays and make sure they're good.A bad fuel pump fuse or relay could cause the fuel pump to not work.
2.If you're fuel pump is priming fine you need to check for spark.Also check for any broken vacuum lines.Hopefully it's just something simple.I had to replace my fuel pump a few months ago.
Old Jan 16, 2010 | 9:01 AM
blebs's Avatar
Sounds like a crankshaft position sensor failure to me. I'm doing one today. Same issue.
Df0927
Dec 23, 2013 4:18 PM
perry2326
Oct 19, 2013 10:25 PM
Kilokk
Sep 15, 2012 7:54 AM
gnrrunner
Jan 29, 2011 7:21 PM
pro_51492
Jan 29, 2010 11:41 AM
