Platform: J-body
1998 2.2 cavalier cooling help needed
Old Apr 23, 2018 | 8:14 AM
Kennyk's Avatar
Default 1998 2.2 cavalier cooling help needed
car gets hot I replaced the water pump, thermostat, temp sensor, radiator is not plugged, pressure tested the cooling system ok . Coolant does not seem to want to flow through the radiator, What could the issue be I’m stumped
Old Apr 23, 2018 | 8:24 AM
bypass the heater core and see what happens. these cars were notorious for blocked heater cores causing an overheat condition.
Old Apr 23, 2018 | 8:50 AM
Kennyk's Avatar
Default I can try that
the heater for seems to be the only thing cooling the engin and it blows heat quite nicely
Old Apr 23, 2018 | 8:52 PM
i know its sounds crazy but don't discount it. If you don't get good flow thru the core on this model you'll overheat. go over to jbody.org which is a cav forum. there will be people who have replaced everything and finally fix it with a heater core.
Old Apr 24, 2018 | 11:00 AM
Kennyk's Avatar
Default 😀
Does sound crazy but I’ll as you suggest and thank you verymuch
Old Apr 25, 2018 | 7:42 AM
Kennyk's Avatar
Default Not fun
this jbody.org is no fun and a pain to register almost impossible
