Platform: J-body
1999 z24 issue
Old Mar 26, 2007 | 8:29 PM
Kyoshiro's Avatar
Default 1999 z24 issue
Ok my brights don't work. My daytime running lamps work and they are the same bulb. I checked the relay and it seemed to be working just fine..Im assuming its the right relay since it clicks with I try and tun them on. Also clicks when I turn the fogs on too. Im getting no power output with the multimeter on the bulb connectors. Sooo.. any ideas of whats going on?
Old Mar 27, 2007 | 12:01 AM
golfer's Avatar
Default RE: 1999 z24 issue
Is the " bright " indicator lit on the dash ?
It could be the DRL module not allowing the full voltage to be switched for the bright lamps.
Old Mar 27, 2007 | 1:44 AM
Kyoshiro's Avatar
Oops some info I left out. No the Bright light indicator doesn't show. In fact when I switch to the brights....The DRL indicator comes on instead.
Old Mar 28, 2007 | 12:29 AM
golfer's Avatar
Try putting your park brake on to disable the DRL then try the brights.
Usually the bright indicator will light when the switch is engaged , but it sounds like a relay is engaging but not allowing the voltage to reach the lamps. I'm still thinking it's the DRL module.
Just a thought.
Old Mar 28, 2007 | 1:46 PM
Kyoshiro's Avatar
I will look into it when i have more time . Thanks for your help.
Cprosh
Feb 27, 2015 12:15 AM
perry2326
Oct 19, 2013 10:25 PM
Don Meadows
Oct 4, 2013 12:32 PM
hook2
Aug 18, 2011 10:01 PM
modracer
Mar 1, 2009 2:57 PM
