Platform: J-body
2003 cavalier coup
Old Jan 5, 2015 | 7:41 PM
wert7's Avatar
Angry 2003 cavalier coup
driver door latch broke, being replaced. luckily it was open when this happened. power window freezes also along with door . actual door ,top and side?? could this be an alignment issue. evry hting else is special
Old Jan 5, 2015 | 9:05 PM
if its freezing to the weather strip; apply silicon spray or silicon emulsion is designed to prevent this and prevent cracking.
Old Jan 5, 2015 | 11:41 PM
sledge.impy's Avatar
Can you post in full, complete, sentences?
Have whoever is replacing your door latch check the window tracks and alignment.
If it's your window motor getting weak - you might be able to "help it" and push the window up with your hand while engaging the UP switch.
If your track is bent out of whack and mangled - it needs replaced.
HoneyPumpkin
Mar 11, 2021 5:26 PM
Toddbrandon28
Sep 26, 2014 7:26 AM
perry2326
Oct 19, 2013 10:25 PM
atomheartmother
Jun 29, 2008 9:41 AM
stepin
Jul 29, 2005 4:07 AM
