Platform: J-body
2003 Cavalier starting problem
Old November 2nd, 2006, 2:57 PM
fmazur's Avatar
Default 2003 Cavalier starting problem
In the early morning when it is still cold outside(45 degrees or lower). After starting the car, there is a loud “whap whap whap” noise, sounding like it’s coming from the dashboard area. The engin shakes and bucks. This just started a few days ago. Once the the outside temperature gets into the mid 50's or above, the car starts/performs A-OK and purrs like a kitten.
Thanks for any insight into this.
Frank MAzur
Old November 3rd, 2006, 7:41 AM
beckeruti's Avatar
Default RE: 2003 Cavalier starting problem
have you checked the simple stuff
like oil level
belt condition
transmisson level (if you can)
also you said under the dash is the heat on when u start the car and what setting is it on
trying doing something different on the settings when you start to see if its something in that area
good luck
Old November 3rd, 2006, 6:21 PM
fmazur's Avatar
I will try what you suggested. I will have to wait till the early AM as the car functions well when the temp. is above 55. THe car only has 35,000 miles on it and I have always changed oil every 3000 miles. Problem started suddenly a week ago. Thanks for your suggestions
2003chevycavalier
March 4th, 2014 7:25 PM
jason33
November 14th, 2012 12:42 PM
linda018
June 4th, 2008 5:36 PM
robin_hood
September 13th, 2006 10:45 PM
Quick Reply: 2003 Cavalier starting problem
