Platform: J-body
2004 cavalier sputtering and stalling
Old Nov 14, 2015 | 6:38 AM
giarc74's Avatar
Default 2004 cavalier sputtering and stalling
Hi guys. New here . I have a 2004 2.2 liter cavalier that sputters bad and sometimes stalls. So far changed coil packs fuel pump spark plugs and wires and now at a loss. Can anyone please give me some input as to what else I should be looking at here . Any help appreciated thanks
Old Nov 14, 2015 | 5:04 PM
all the time? at idle, ok at higher rpm? hot/cold? lack of power?
SES light on? If yes, post the codes.
Old Nov 15, 2015 | 12:28 PM
giarc74's Avatar
Default no lights on in dash
It's sputters on idle and hi rpm while running hot and cold. There are no ses or other lights on in the dash except t/c. Traction control. With no lights on makes it even harder to figure out. Has new spark plugs. Coil pack . Fuel pump and what looks to be like a new computer.
Old Nov 15, 2015 | 5:36 PM
Kinda hard to say without having any live data to view.
Old Nov 17, 2015 | 3:45 PM
giarc74's Avatar
Default changed pcm
I just changed power train control module. Now still sputtering but now I have little orange engine light on
Old Nov 26, 2015 | 2:32 PM
Cavy94's Avatar
Consider these steps:
1. Inspect entire fuel system(fuel lines & pump) and do fuel pressure test.
2. Do a spark plug test.
3. Do a fuel injection test to determine if the fuel injectors are spitting the right % of fuel.
4. Do an air leakage test to check for air leak into the intake.
Stalling & Sputtering means you are not getting the right combustion to sustain t he engine. Question.....what is causi
ng this. Do the tests and you'll no if you have the right air & fuel %. If the problem persist, we'll go to bed phase 2. Good luck.
Old Nov 26, 2015 | 11:50 PM
cleveland63b's Avatar
bit of a guessing game without being there but i'd definitely start with fuel pressure and volume tests...you have good fresh fuel?
