Platform: J-body
92 Cavalier start problem
Old Jan 11, 2007 | 11:57 PM
sanddraco's Avatar
Default 92 Cavalier start problem
I've read the other forums on the cavalier not starting but they didn't help me with this. I turn the key in the ignition to on and the lights come on and everything, but when I turn to start everything flat out dies as if the battey loses all it's power suddenly. I just bought a new battery with plenty of cold cranking amps, howeve when this happens I can charge the battery andthat seems to work. So I think it's an electrical leak in my car somewhere, but someone mentioned the fuseable link or something might be the problem, but I don't know much about that. Could that fuseable link cause that problem? So, as far as I can tell it can either be an electrical leak, a faulty battery (even though it's new), maybe ice forming somewhere, fuseable link, or car thats tired of driving. any other ideas? oh and the alternator is new also, so that can't be it
Old Jan 12, 2007 | 9:46 PM
golfer's Avatar
Default RE: 92 Cavalier start problem
So to see if I understand your problem .... you bought a new battery and it seems to drained when you try to start the car. You charge the battery and then the car starts.
Was this the reason for getting the new battery in the first place ?
Are you sure the alternator is working to charge the battery ?
If the alternatorisworking properlythen your assumption could be correct about something draining the battery.
you can check out the proceedure i posted in this link :https://chevroletforum.com/m_11221/tm.htm
jstreet
Feb 18, 2012 7:14 AM
Rusty Bolt
May 26, 2010 4:30 PM
bracca
Jul 12, 2009 6:14 PM
atomheartmother
Jun 29, 2008 9:41 AM
