Platform: J-body
93 Cavalier with no spark, a real head scratcher here.
Old Apr 5, 2010 | 3:33 AM
Roanoker494's Avatar
Default 93 Cavalier with no spark, a real head scratcher here.
1993 Cavalier wagon with a 2.2L and auto will start first thing in the morning but dies after 5-8 minutes. The car will usually restart but only run 20-30 seconds before it dies again and has no spark at all. First thing I think of is the ignition module so I pull it off and have it tested at the parts store, it tests out fine. He actually tested it three times in a row to make sure it was working correctly, passed every time. Bought a crank sensor, plug wires and two coils and reinstalled everything and ended up with the same results, runs for 5-8 minutes and dies with no spark afterward. Let the car sit for several hours and it will do it all again for you, fun game but makes it a pain in the rear to get to work. During one of the times it was running correctly I pulled and twisted on all the wires and connectors, looking for a loose connection, with no change at all, it still died after 5-8 minutes. SO..... It is not the module, the coils, crank sensor, plug wires, loose connection, muffler bearing, firewall gasket or blinker fluid. I also checked the ignition switch, the actual electrical switch, and it is functioning correctly. Has anyone been through this before? Could you share your knowledge? Possibly a ECM problem? Do theses cavaliers have a auto shutdown relay?
Old Apr 8, 2010 | 7:01 PM
okay, figured it out. The problem ended up being the ignition module, even though it tested as being good at advance auto. Found a whole module/coils pack at the salvage yard for $75 and it is back on the road, new module was $149 at the parts stores.
Chevrolet Forum News
Dec 28, 2014 6:18 PM
B-fast
Nov 6, 2013 7:43 AM
parallel
Jun 1, 2013 12:50 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
NovaProject
Nov 6, 2010 12:35 PM
