95 Chevy Cavalier Oil Psi
I am trying to install some after market auto gages into my cavalier. I was thinking of installing a "T" fitting into the block where the factory sensor is, or trying to tap into the electrical circuit It is a 3 wire switch and it is just a light in the dash it does not monitor any oil gage for pressure, I also confirmed the ECM does not read actual oil PSI by using an OBD Plug, it just monitors the fact it has oil pressure. I am looking good wiring diagram to help explain the 3 wires in the oil psi circuit or of it is possible for a good location to put maybe the after market pressure sending unit into the block somewhere.
You can put a Tee where the current switch is and put both sending units in the same port. You need to connect the old one to keep the ECM from sending a no oil pressure signal.
Okay I thought that would have been my solution. I was just hoping to get lucky there doesn't seem to be a lot of room in that area of the block. Make it work. Will post with what it looks like.
shayandude
June 4th, 2022 4:10 AM
amundy
February 20th, 2014 5:05 PM
sdrammm696969
October 10th, 2010 1:37 PM
For Sale: gm 120 psi oil gauge nos
foxhunter
July 13th, 2010 10:56 PM
SPL Tech
June 9th, 2009 7:02 PM
