96 2.2 auto in limp mode, cel on, esc on
drivin down the highway at 70 like usual when suddenly no noises lotsa lights and im slowing down quickly.esc light on steady, cel on steady,in limp mode. made it home at 18 mph. went to oreillys for a code reader. got it , followed directions( at least 4 or 5 times) got absolutely no response or codes or anything. Acting like it was being turned on and not plugged in to anything at all. code reader works fine on other vehicles. thoughts, ideas, and most suggestions are greatly appreciated. Thank you
Welcome to the forum. Check for battery voltage on pin 16 (rightmost pin, bottom row as you view the connector under the dash) and ground on pin 5 (5th pin from the left, top row). If battery voltage absent, check the 15A CIG fuse.
ok so the fuse was blown. i put in another and it blew when i started it. put in 1 more after checking wiring. it didnt blow so i cleared comp by disconnecting battery and started itl both lights came back again. what all is on this circuit? hafta do more digging i think. thank you
The CIG fuse is just for the auxiliary power sockets and, incidentally, the OBD connector. You must have a short in the wiring or power sockets. What are "both lights" and did you scan for trouble codes?
both lights are ets and cel. i dont have the code reader anymore. can it be done without a reader? maybe a paperclip? i dont know which terminals to jump or if it can be done
ok i have searched for a while and cant seem to find the knock sensor. do you have a diagram of where it is located? i think it is right below the coil. im ready to pull the intake so i can see better
That's probably not going to help. It's below the exhaust manifold (torque to 143-196 lb-in or 16-22 N·m):
everything ive read so far says its on the firewall side however im not convinced it is since i have found 3 different possible locations so far. wish i had access to something from gm. im only saying this because the exhaust mani is in front and i dont see any sensors or wiring there. i just finished changing one on a 3vz toyota. that was hard enough to locate
