97 Cavalier PCM / Alternator Noise
1997 cavalier. The alternator is making a high pitch electrical sound (you have to put you ear up to it to hear it) after the engine is turned off. After pulling the relays, breakers, and fuses, it stoped when the PCM fuse was pulled. The 4.96 volts at the alt plug stoped also. I put the fuse back in and 0.0 volts and no sound. Restart the engine, the alt charges. Shut it off, and the sound is there, unplug the alt plug and have 4.96 volts. This is also draining the battary. What cha think?
Has anyone figured this out? I'm having the same issue with a no start thats flooding the plugs and backfiring through the throttle body. The mechanical timing is correct the compression is correct the control module is good the crank sensor is good the map sensor is good I mean I have gone through this car and cannot figure it out. Any help at all would be greatly appreciated
Thanks for the reply, I have also changed the coil packs with known good ones I had laying around. I'm down to the computer screwing with the timing I have checked absolutely everything else.
Xerklite
April 27th, 2013 9:14 AM
2000burb
February 28th, 2012 12:42 PM
