Platform: J-body
97 z24
Old May 21, 2014 | 6:07 PM
RichieRich's Avatar
Default 97 z24
Hey guys! I have a 97 Z24 and I had jump started a car and now my fan doesn't
work! I checked the fan motor and it works fine. I had the PCM replaced along with all the fuses/sensors and it still doesn't come on. I have an after market fan set up but it also sucks! Doesn't work properly. Could the factory wiring be fried somewhere between the PCM and the fan motor or is their other fuses/sensors that might be connected to the cooling system that might be damaged? Thanks!
Old May 21, 2014 | 6:19 PM
sledge.impy's Avatar
Unplug the fan electrical connector and test the voltage. Turning on your AC should send the signal to turn on the fan.
Old May 27, 2014 | 3:28 PM
RichieRich's Avatar
i did that and it still doesn't work. It doesn't come on with A/C either.
perry2326
Oct 19, 2013 10:25 PM
Don Meadows
Oct 4, 2013 12:32 PM
98z24guy
Feb 28, 2006 7:38 PM
techno_farmer
Mar 13, 2005 9:41 PM
