Platform: J-body
99 Cavalier PCM replacement
Old May 23, 2017 | 1:37 PM
LucasKnussman's Avatar
New User
Awaiting E-mail Confirmation
Default 99 Cavalier PCM replacement
Hey All,
I am looking into replacing my PCM/ECU after having an issue with my radiator fan not spinning up, and tracing all of the electrical back to the PCM. Before I just went and replaced this relatively expensive part I wanted to ask something. Is it a good idea or even possible to just pull another PCM from another cavalier out of a junkyard as long as it has the same engine and transmission, and is there anything I should watch out for if I do end up replacing this thing.
Thanks!
Old May 23, 2017 | 3:50 PM
kevinkpk's Avatar
You should be ok, I'd suggest checking ebay. Look for one used that the person can burn the eprom with your vin
Old May 26, 2017 | 1:54 AM
New User
how important is it to get the vin tied to that pcm?
Old May 26, 2017 | 9:56 AM
for most vehicles its required for theft deterrent. older cavs use the ipc for theft deterrent...so you may be able to just install a used pcm without programming.
maybe check out jbody.org a cav forum.
