Anyone want to help me with an experiment? Have a 1997 1998 or 1999 Cavalier/Sunfire?
I believe my PCM is dead. Before I spend the money to get one and have it programmed I was hoping someone would volunteer to help me or maybe even know the answer.
I'm hoping someone could disconnect their battery and unplug both harnesses from their PCM then re-connect their battery and turn the ignition on and try to crank etc and post the results.
I have tried everything I can think of to resolve my issue. I have traveled to the end of the internet. I have seen many wiring diagrams. I have tried and tested every fuse, relay, wire, and fusible link but still no luck. All I have is a good battery providing proper power to a brand new ignition switch but when I turn it I get nothing. No clock on the radio. No lights on the instrument cluster. No power to the starter or anything past the ignition switch. When I open the door the dome light comes on. The horn blows. The emergency flashers work. The headlights come on. The key even ding ding dings when I put it in the ignition. I can't even scan for codes.
Is anyone with a 1997 to 1999 Cavalier or Sunfire willing to try this?
My thread on this forum is located here for other info: https://chevroletforum.com/forum/cav...-lights-44372/
I have started threads on many forums with no luck.
If you are willing to help please let me know. I'm broke and can't afford to throw money at it anymore.
e84
Jan 10, 2015 11:48 AM
Cavigurl85
Aug 16, 2006 8:33 AM
Cavigurl85
Aug 6, 2006 10:12 PM
