Platform: J-body
brake drum cylinder removal question
Old Aug 10, 2009 | 12:43 PM
mdjbhouse's Avatar
Default brake drum cylinder removal question
I have a 96 2.4l cavalier with a leaking rear brake drum cylinder and so far so good as I've taken off the drum and shoes etc along with loosening the brake line.
But I'm not sure how the cylinder gets removed.
Is it held in place by a couple of star headed screws that I would remove from the back?
MD
Old Aug 10, 2009 | 1:49 PM
mdjbhouse's Avatar
So I went out an bought a Haynes Manual but all it says is remove the two bolts (big help).
It would appear there are 'female torx sockets' out there so I'll look for that.
Update:
Got the e-torx required to remove the cylinder but now it looks like I can't remove it from the car without also removing the 4 hub bearing bolts to get enough clearance.
Sigh, it just seems to get more involved at every turn. Now I need a 55 Torx bit (back to the auto store).
Update 2:
Gave up. Couldn't get the bottom two hub bolts off so put er back together and will take it to the garage tomorrow.
AndrewSE
Jan 31, 2010 12:10 AM
offroadinjersey
Oct 6, 2009 12:15 PM
dcoperator
Mar 21, 2009 9:36 PM
cook
Mar 13, 2008 8:01 AM
stewdogg
Nov 30, 2006 2:33 AM
