Platform: J-body
Check Engine While Driving
Old Oct 2, 2011 | 7:44 PM
dkalleck's Avatar
Default Check Engine While Driving
1991 Cavalier, 2.2L. I'll be driving down the road when the check engine light comes on. It stays on for maybe 1 minute or so, then turns off. It's too old for my obd2 scanner.
How can i figure out what keeps tripping the light?
Old Oct 2, 2011 | 10:21 PM
johnnywayne2290's Avatar
I had the same problem on my 94 and it was the o2 sensor getting a false reading from exhaust leak but it could also be the sensor starting to go bad in your case cause it likely does it under a load once you hit hills or curvy strech in road
Old Oct 3, 2011 | 5:17 PM
the easiest way is to get a voltage meter and back probe the sensors with a safety pin or something and with the car running they should not go over half a volt unless its its the mass air flow sensor and it should say under 5 volts if they are outside the range you found the bad sensor
srfing4ever
Dec 2, 2014 9:06 AM
oldmanROn
Uplander
Jun 18, 2014 10:31 AM
99SuburbanTX
Sep 9, 2012 5:09 PM
metalmike187
Dec 19, 2010 11:22 AM
FRENCHEVY
Oct 27, 2009 8:34 PM
