Platform: J-body
Clutch Pedal Over-Center Feeling
Old July 1st, 2013 | 11:04 AM
Silent_J20's Avatar
Default Clutch Pedal Over-Center Feeling
Good morning,
I have a 1998 Cavalier 2.2 that has weird clutch pedal behavior after a transmission/clutch replacement. What I know:
-Manual transmission came from a similar year Pontiac Sunfire
-Clutch was "new" (likely remanufactured/rebuilt) for the 1998 Cavalier.
-Clutch master cylinder was not replaced. Not sure about slave.
Work was done by my father and brother. My father is very familiar with car mechanics and has done lots of work himself. However, now the clutch pedal occasionally stays on the floor. I can still shift normally and drive, and it has the correct pedal feel for 2/3s of the travel. At 2/3 of travel, the pedal resistance lessens and feels almost as if it goes 'over-center' and will get stuck on the floor (when pedal needs to be pressed fully to start the car), it will spring back to normal after lifting it slightly. No fluid loss or leaks has been found. Any help tracking this down would be great. Thanks,
Brian J
jgrossman
September 8th, 2020 11:34 PM
CalebK08
December 21st, 2012 12:52 PM
thisnthat
November 20th, 2012 11:36 AM
Fizzerman
July 26th, 2010 12:35 AM
stickpony
March 21st, 2010 9:47 AM
Quick Reply: Clutch Pedal Over-Center Feeling
