How to program 03 cavalier keyless remote
I bought a keyless entry remote, and I don't want to pay the dealer to program my remote. Can someone offer the correct steps to do this.......2003 Chevy Cavalier
Here is what GM says, but I can check another source to see if you can do it without a scan tool.
Transmitter Programming
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
Install a scan tool.
Turn ON the ignition with the engine OFF.
Select Body Control Module.
Select Special Functions.
Select Program Key Fobs.
If you are adding a transmitter to the system, or are replacing a transmitter, choose the Add/Replace Key Fobs option. This allows new transmitters to be added without deleting those currently programmed to the module.
If you are replacing all transmitters or none of the transmitters are working, choose the Clear memory and Program All Fobs option. This prevents lost or stolen transmitters from being used to access the vehicle.
Follow the scan tool on-screen directions.
After programming the last transmitter, remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
ilanitin
Uplander
Dec 26, 2008 7:54 PM
