Platform: J-body
i have a 1999 Chevrolet Cavalier 2.2L SFI
Old Feb 14, 2013 | 1:04 AM
Jeremiah Young's Avatar
Default i have a 1999 Chevrolet Cavalier 2.2L SFI
i have a 1999 Chevrolet Cavalier 2.2L SFI OHV 4cyl. it will start but wont stay running. i have checked for codes and there is none. you can hear the fuel pump and change the fuel filter. i have psi at the injectors. i also pulled them and checked them. all 4 are firing. i have checked number 1 for spark and it has spark. only way to get the car to run is to pump the gas pedal. but still runs bad. i can get it to rev to about 3k and hold for a few sec's then it wants to die.
Old Feb 14, 2013 | 11:49 AM
Check your fuel pressure. Sounds like it may be low. Just having fuel is not enough, it has to be at the correct pressure.
Old Feb 14, 2013 | 7:23 PM
Default so far
i checked fuel psi and its 45 psi
i have spark on all plugs
right now i am leaning to thief mode problem
Old Feb 18, 2013 | 4:03 PM
go-part's Avatar
Former Sponsor
This sounds like a sensor issue causing your problem.
When was your last tune up?
isrummell
Aug 11, 2012 12:23 AM
carpenterhendrickson
Jun 11, 2010 9:41 PM
hammerandnails88
Aug 9, 2009 11:45 PM
raybaloy
Aug 29, 2007 3:58 AM
mach1misfit
Feb 12, 2007 12:39 AM
