Platform: J-body
Idle
Old Mar 3, 2011 | 7:49 AM
jimbo141's Avatar
Default Idle
Can someone tell me what the idle rpms should be at? My idle is at 625rpm and that seems a bit low. Also can you tell me how to increase the idle? I have a 2002 2.2 w/automatic trans.
Old Mar 3, 2011 | 6:39 PM
EinST's Avatar
The PCM maintains the idle with the IAC valve. It'll keep it as low as possible without stalling under various loads. There's no adjustment to be made.
Old Mar 3, 2011 | 9:52 PM
EinST's Avatar
Okay, I just got around reading your other post about it stalling "with the heater selector switch being on." Maybe the HVAC control module is requesting the A/C compressor to be ON which turns on the compressor and the cooling fans? I'd try unplugging the electrical connector from the compressor clutch to eliminate it first.
Spike44
Nov 26, 2018 8:22 PM
Sethyates72
Feb 1, 2014 7:53 AM
Thermool
Jun 20, 2009 6:41 PM
Jen2002blazer
Sep 23, 2005 4:52 PM
Spike44
Jan 21, 2005 11:58 AM
