Platform: J-body
Interior lights
Old Oct 4, 2011 | 5:23 AM
kidd414's Avatar
Default Interior lights
Hello,
Recently bought a 2002 Cavalier for my daughter. The dome and map lights do not work. I popped off the lens and seen that they had no bulbs in the sockets. I knew right away what was going to happen next, and it did. I put bulbs in and they work beautifully, ALL THE TIME!!! What may cause the lights not to turn off. Both door switches seem to move in and out easily, but they still could be bad??
Any help is appreciated,
-John
Old Oct 4, 2011 | 12:37 PM
EinST's Avatar
Welcome to the forum. The only way the dome lamp and both reading lamps (regardless of the individual reading lamp switch states) to be lit constantly is a short to ground in the wiring going toward the I/P dimmer switch or something internal to the I/P dimmer switch.
Old Oct 7, 2011 | 9:09 PM
spedaleden's Avatar
I would run a new wire from the back of the dimmer. (Cut factory wire at dimmer) run the other end up to the dome light. Cut factory wire and attach externally run wire to dome light and see if it works. If it does then you need to run a new wire.
My 2 cents
Dennis
nysmedic
May 13, 2013 10:04 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
jamesq
Nov 2, 2010 6:02 AM
skdevore
Aug 26, 2009 10:18 PM
