Platform: J-body
keys stuck help
Old Jan 12, 2011 | 5:09 PM
jhnlesch's Avatar
Exclamation keys stuck help
hi i got a 1991 chevy cav. with 2.2l automatic. the keys will not turn back to the off position so i cant get the keys out . also the car will not stay running if key is turned forword ( it will start and run but only if you keep the key all the way forword)as soon as you let the key go back the car cuts out and dies. any ideas on what it is?
also the trick with putting screwdriver in the little cover at the bottom of the steering wheel cover dose not work here . this must of been before chevy had to put it there .
also thanks for any help you people may give
BigblackHo3
Apr 5, 2013 8:54 AM
SweetEmotion
Apr 3, 2012 8:09 PM
swerhun2003
Nov 12, 2010 12:01 PM
swerhun2003
Nov 11, 2010 7:43 PM
skillettxxx
Jan 6, 2008 6:31 PM
