Platform: J-body
No crank
Old Mar 18, 2019 | 3:07 PM
Stevescummins's Avatar
Default No crank
My 04 suddenly won't try to crank. New starter and battery. My scanner won't communicate. When I try to start car the odometer says error. All fuses and relays are good. Any ideas. I did move shifter to neutral and back to park a few times with no change. Thanks.
Old Mar 18, 2019 | 3:08 PM
kevinkpk's Avatar
Did you try to crank it with the shifter in neutral?
Old Mar 18, 2019 | 3:15 PM
Yes I did. I can jump the starter and it will crank but won't start. Ran fine when I parked it and the next day it had this problem. I'm wondering if the ecm died.
Old Mar 18, 2019 | 4:02 PM
kevinkpk's Avatar
Ok, if it where me, chock the wheels, key to on, then jump starter, see if it will.
Old Mar 18, 2019 | 4:14 PM
kevinkpk's Avatar
Probably ignition switch.
Old Mar 19, 2019 | 12:33 PM
With key on i jump starter and it will crank but won't start. Odometer says error.
