Platform: J-body
no lights
Old Apr 15, 2013 | 7:36 AM
kidster's Avatar
Default no lights
yesterday when I was driving home my day light dash indacator light started to flash , when i got home home noticed I had no daytime lights , I switch the headlights on and they weren't working either but if I turn the high beams on they seem to work. I tried changing the day time relay and it did nothing. Now this morning the daytime indacator on the day isn't on ay all anymore. Does anybody have any idea what this might be the vehicle is a 99 cavalier with a 2.2 L.
Old Apr 15, 2013 | 11:47 AM
Always check the fuses first before going on to anything else.
Old Apr 15, 2013 | 4:23 PM
kidster's Avatar
Sorry I forgot to mention that I checked the fuses first then chanaged the relay,
Thx
Old Apr 16, 2013 | 7:19 AM
Jeff Collision's Avatar
You may have a bad wire in the headlamp harness. This is the most common problem on these cars. You have to trace down the broken wire usually one of the blue ones or have to replace the headlight harness.
Old Apr 18, 2013 | 12:20 PM
kidster's Avatar
Finally got a chance to take a good look , and Jeff you were right found a the blue wire going from driver side to passenger side was broken where the 2 blue wires join the one blue wire. thx for the help.
Old Apr 19, 2013 | 1:44 AM
tony55's Avatar
this type of problem always coming when wire damage if it will sudden turn off so you have to check first fuse otherwise wires as jeff resolve your problem.
PatrykKoul
Apr 26, 2023 9:14 AM
TRUCKDIVA
Jul 22, 2013 6:48 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
cowboys
Dec 18, 2006 12:28 AM
