Platform: J-body
Rebuilt engine, now transmission issues
Old Oct 30, 2015 | 2:56 PM
From303's Avatar
Default Rebuilt engine, now transmission issues
First, I should explain, I am not a mechanic. My Dad is doing all of the work and I was just looking for a way to help.
It's a 1997 Cavalier and the engine went out. My Dad rebuilt it with the help of a machine shop and has it put back together now. Except when you try to go forward, the engine revs but it doesn't gain much speed. If you keep at it, slowly it will get up to 35 and even 50 miles per hour. Once you are there, it goes smooth but you can never keep up with traffic getting to those speeds. He said he can tell from the sounds that it's in the transmission. Which is an automatic.
Any suggestions?
Old Oct 30, 2015 | 2:59 PM
From303's Avatar
Oh and I didn't notice any transmission issues before the engine went out.
Old Oct 30, 2015 | 7:47 PM
torque convertor stator maybe? if it doesn't lock and hold you will have poor torque multiplication, but it will cruise just fine.
Old Oct 30, 2015 | 8:31 PM
From303's Avatar
I looked that up on howstuffworks and that makes a lot of sense! I recommended it to him and he said he believes the transmission bands need to be adjusted. Do you think that could be the problem instead?
From what I read, your idea makes the most sense. I'm not gonna argue with that man that's doing the work though
Old Oct 30, 2015 | 9:45 PM
nope. Maybe if the transmission was from 40 years ago or from another manufacturer that actually require band adjustment.
is the kickdown/tv cable adjusted properly or is it fully electronic? this is an important input for sensing load?
