Platform: J-body
remove radio fm/cd in cavalier 2002
Old May 6, 2008 | 3:24 PM
karaoke04's Avatar
Default remove radio fm/cd in cavalier 2002
I need to remove the radio from mi car , Can you help me???
Old May 6, 2008 | 7:25 PM
shawnvw's Avatar
Banned
Default RE: remove radio fm/cd in cavalier 2002
These are fun.......remove the phillips screw from the defrost vent, remove the defrost vent, there are 2 7mm bolts under there. pry off the right side of the dash, 2 mor 7mm under there. open the glove box, 3 or 4 more 7mm there. Peek through the access hole in the glove box and you'll see 2 gold coloured 7mm holding a steel bracket down....remove these. Pry the left side of the dash off, remove another 7mm. The entire top of the dash should come off now. There are clips above the instrument panl so it may be a little tight. Now there are 3 or 4 7mm bolts going straight down into the top of the trim around the radio underneath of the panel you just took off. Start pulling the trim rearward to release the cli[ps and d\c electrical connectors as you go. Carefull with the dimmer switch as it is easy to break. 3 7mm holding the radio in and you're out
RNCharlie
Feb 19, 2011 8:42 PM
ridgemeadows
Jan 24, 2010 3:27 PM
thedillybar
Aug 6, 2009 11:18 AM
adamant
Feb 15, 2009 8:49 AM
camarofreak
Oct 15, 2008 7:34 PM
