Platform: J-body
rough idle and abs light
Old Aug 2, 2011 | 10:34 PM
shiftrus's Avatar
Default rough idle and abs light
hey,
i have a 1995 2.2 cavalier automatic. it has a rough idle at start up and persists to be rough the whole time i drive it. its fine on hwy but as soon as i let go of the gas to hit the brakes it wants to die. i put new plugs in it and i noticed plugs 2 and 4 (counting left to right looking down at engine when standing in front of it) are blacker then the other 2 which are a nice brown. i checked spark by pulling one plug wire at a time while it was running and put it near metal and seen the spark jump to all the plugs and they seem fine. it smells like its running rich, everytime i rev it up it shoots black smoke out the tail pipe which smells rich. and also my abs light is on and i have no abs. i checked the fuses under the hood and there good. the brakes are hard to use under low speeds but as soon as u get it up to 50 and above they are easy to puch but still no abs just solid brakes. is there anything to check for? are cylinders 2 and 4 run off the same ignition coil? would a bad brake booster wreck the vaccum of the motor and make it run bad and also throw the abs light on? any ideas?
thanks in advance any help is appreciated.
macmommy
Apr 22, 2020 1:23 PM
Sethyates72
Feb 1, 2014 7:53 AM
rdevlinmc
Mar 25, 2010 4:11 PM
Deteoni
Mar 28, 2009 1:39 PM
maddmatt16052
Nov 24, 2006 9:05 PM
